The cameras have a hard time charging. The smart hub is useless! It’s a pain in yhe @$$ to connect your cameras after they’ve already been installed. The app won’t format the usb solid state drive. The smart hub doesn’t send record on the usb SSD. And if it does you can’t see any recordings using the app!
Arlo SUCKs
These steps may help you with the local storage behavior you are seeing.
https://kb.arlo.com/000062818
