Arlo Essential 2nd Gen not saving material
  • 1 Reply
  • 1025 Views
mangelsh1
Hi!
Have you guys experienced issues with the Arlo Essential 2nd Gen not saving material? I do get notified but the material is not saved. I have checked settings, dont have any activity zones and have reinstalled. Is it a new bug?
Is this with cloud storage or local storage?
Do you checked the subscription status?
Also, check the feed settings (press on the ... at the top right of the Feed page).  The filtering settings are sticky, and it is easy to forget that you've filtered out a camera or an event type.
