Hello, i have a small isue with time stamps.
I would prefer to have YYYYMMDDHHMM.mp4 but now since Netgear has gone for the Epoch solution i get this problem,
In the Arlo software it says a movie is recorded say 09.45 June 29.
I save the movie to my computer and convert Epoch and the time is 07.45 June 29.
2 hours off, no reason why as i am in UTC+01.00, (Stockholm, Sweden)
I have restarted but not done a complete reset of the whole system with pairings etc.
Any suggestions?
If the system time is right ( on playback ) , resetting prob will NOT fix anything....
The fact that the epoch time is off is strange , but prob only answered by Netgear Support... may be a bug
As an EDIT...
I checked the EPOCH list...
shows stockholm as gmt +2
Europe/Stockholm (CEST) | Jun 29 2017 18:30:38 | GMT +02:00 | DST |
Thank's for checking!
That explains one of the hours if GMT is used as base for Epoch since GMT is DST flexible...
In the Arlo software it says (UTC+01.00) so it IS a bug in the Arlo/Epoch usage.
I will see if i can pass this on to Netgear/Arlo!
/Joakim
Update.
Just had an hour of chat support and they have no
clue it seems, unclear if the "glitch" is piped on or if it's
a "poof"
I was asked to send a movie through the chat window
and then the chat was gone... 2 hours off confirmed by
recording a live stream and then d/l and check the Epoch
stamp.
I just got an email suggesting this message to be the solution, i take that as sort of confirmation they find it a bug?
