Can't connect a camera to base station.
Blinking blue light forever. All other cameras work fine. Problem camera has worked fine for 2 years. Then, just stopped working. Batteries good. Tried a reboot. Deleted camera, then tried to add it back on. Will not add problem camera back on.
If the blue LED doesn't flash when closing the battery door, verify that the batteries are properly inserted for polarity and that you have only placed them in their slots without pushing down. Close the battery door and let it do the pushing. If still no blue flash, it sounds like you have a dead camera. Oh, yeah, be sure the batteries are actually good, too.
Got the same issue on a camera that was working properly since a year. Could you fix the issue in the meantime?
ManuKast,
Have you tried to remove and re-insert the battery in the camera?
ManuKast,
What are the status LED lights displaying on your base station?
All three green. In the meantime I resetted the base station and set it up to my account again. I then could connect the cam, which was problematic until then. But now I cannot connect the other cams anymore.
When I start the assistant I follow all the instructions (battery, sync button) but it does not connect to the base station, therefore shows an error.
ManuKast,
Are you keeping the cameras within 3 feet of the base station when syncing? Did you reboot or factory reset the base station?
first of all, thanks for your constant support!
Yes I did factory reset the base station After that I could successfully assign the cam that wasn’t connecting before. However now no other of my cams can be connected anymore.
Yes I placed the cam in a range of about 50 centimeters to 2 meters around the base station.
ManuKast,
You are welcome, we are here to help as much as possible.Forgive me if you have done this, it sounds like there may be some interference happening around the cameras. Is it possible to move the base station or router further from each other & try and sync the cameras a few times each until they hopefully get a signal.
Hello,
I'm having the same problem as the OP ..... tryed all the above with no results.
Camera seems it's DEAD ?
~ Thanks, GKU
Problem solved by rebooting my WIFI router and Arlo base station.
Went back into the app and redid the cam setup.
FYI:
Also when installing fresh batteries or a power failure I need to install them twice for them to auto connect back, strange but it's what usually works for me .......... untill I needed to do the above.
~ Thanks, GKU
ShayneS I couldn’t belive it! It works again!
I unplugged my Access Point, which was in the same room some meters away. After that I could add all cams again. Apparently the interference was the reason. During the upcoming weekend I’ll investigate a little more on this issue. I’ll try to just enable 5 GHz WiFi, since I assume the base station is running on 2.4 GHz only. If this works, I’ll enable 2.4 GHz on the AP again and try to allocate a different channel.
Anyways! Big big thanks to you and your constant support! Keep up the awesome work!
All the best!
ManuKast,
You are welcome, have a great weekend.
I have tried several times and changed battery several times and I cannot add a new camera. It won’t sync. Blue light blinks for a ling time and then stops. Not syncing.
Momjo,
What are the status LEDs displaying on the base station?
