  • 4 Replies
  • 4330 Views
Carlos11111111
Can I record in a local drive?
Not with the ooriginal Arlo cam base....The Pro cam base does support local USB drive backup
Carlos11111111
I have two(2) UHB ports in the back of the tower. none of the instructions nor digital manuals tell me what they are for. Do you know?
Carlos11111111
As noted above, if you have the original base, not the Pro, the USB ports are not used for anything.
