Not sure if it has anything to do with the last update, I have an iPhone 6 Plus
Thank you for your help!!!
Since you say it's from the last update, go and check the settings of your MODES
Make sure they are activated and the sense levels are where you want them instead of default levels.
Also an easy thing to do is reboot the base via the power button.. Also power button reboot the phone.
If the above doesn't work you may have to go a bit farther and reset the cameras ( pull batteries and replace ) andmaybe do a full reset ofthe base just incase something got glitched... a full reset will put all to default again, so you may have to re-sync thecams and reset your sense levels/reocrd times.
( so do this last )
my videos have not been recording. I get a notification every time and no recording is available in library. So I rebooted and now 1 of my cameras is off line????
Debk,
It sounds like your cameras/base station may not be on the latest firmware. If you navigate to Settings > My Devices > select a camera/base station, what firmware version is displayed?
Hardware: H7
Dankgilam,
If you are live streaming and recording, the app must be open for the recording to continue. Otherwise, the app does not need to be open to capture motion detection events when the system is "Armed".
