Arlo Camera outside with Magnetic Mount
  • 1 Reply
  • 4129 Views
Howie411
Luminary
Luminary
Is the Magnetic Mount Strong enough to hold the Arlo if I put it outside or do I need to buy one of the mounts where it screws on?
arlocurious
I think you are asking if you can use this:
magnetic mount
Or if you need this:
mount with screw
It may depend on the angle you need to set the camera to:
  • I have a camera mounted to the side of a wooden fence using the magnetic mount and it works great.
  • I did use the mount with screws to mount a camera under the roof overhang.  That gave me more flexibily with the angle.
