Arlo Camera, only one camera recording to Local HD storage
Hi Folks
I have 3 Arlo cameras (not pro), I have a 300gb external USB drive connected to the Pro basestation but only one camera is getting its recordings to the local storage, Front Door, External Upstairs and Back Door, where only Front door is recording, at a loss to see any difference in the setup of the devices so at a loss as to where to look.
Any help or direction will be greatly appreciated.
Kind regards
Nialler
It's not a per camera setting so something else is going on. Start by rebooting the base. Are the cameras all recording to the cloud? What mode are you using? Have you tried creating a new custom mode for testing?
Hi jguerdat
Yes all cameras recording to cloud, in the phone app they've also got the USB symbol beside them denoting that they're recording to the external drive, standard inbuilt "Armed" mode with tweaks to the sensitivity of motion. I shall create a custom setting this evening and report back. Thanks for your suggestions.
Nialler
