Arlo Camera Flashing in IR Mode
So when my front porch Camera starts to record at night recently it has begun to blink on and off in IR mode. There is a porch light nearby that has been at the same location since installation. I have a video but cant seem to insert it here. When you watch the video its switching back n forth between balck-white to color images very second. I tried a different camera and it still does the same thing. Any ideas ?
I'd guess the external light level is right at the point of where the switch happens for night vs. day (color) recording happens. My deck light is close to the camera and will switch to color when it turns on with such switching back and forth.
swoodard,
I agree with jguerdat. It sounds like at that location the light level is right on the cusp of too little and just enough causing the Night Vision feature to engage/disengage. If two cameras behave this way in this location, I would advise relocating the camera or, if applicable, turn off the night vision feature on this camera as it does seem to appear from your first image that the lamp on your porch provides enough light for the camera to be viewed.
Yes, after looking at the two pics.... I say if able, increase the wattage of the outside bulb ( to give more light ) and turn off the IR.
First pic has better definintion
