Arlo Basestation VMB3000 add to existing system
  • 2 Replies
  • 3302 Views
krisfirth
I have a system and I now have a second base station how do I add this to the system
Simply start up the prgm/app and add device, picking the new Base.
The second base will allow you to expand you actual coverage area ... and you sync the cameras  to each base by distance/signal when you split them up.
Only possible down side ( tho I see it as a Plus ) is that both bases appear in the prgm, with assocated cameras underneath, EACH base now runs it's own schedule, arming, etc as they are actually separate
krisfirth
Thanks Mac all sorted
