Arlo Base station bridge
Hi All,
We really really need a base station bridge. No amount of positioning allows good signal for both of my cameras (the cameras are too far apart) Buying an additional base station just isnt a realistic option....far too expensive.
Please please please can you guys develop a simple plugin bridge that will extend the WIFI signal of the base station. Something similar to the Arlo doorbell bridge would be perfect. Or allow the wifi signal of the basestation to be extended by off the shelf wifi extenders.
Based on the cost of the system in the first place and the cost of additional cameras, a second base isn't nearly as costly. Even if a bridge were available, I'd wager it wouldn't much less than a base. People have them as low as $18 on eBay and and a new Pro model with siren and USB ports that can be used for $64 on Amazon.
I saw several bases on eBay. And why are you looking at Ultra bases when Pro bbases are much cheaper?
It helps if the posts are in the appropriate forum, such as the Ultra one here. I was responding due to the location of this post.
