My system is set up with a Verizon Jetpack and I use a Netgear extender for my base station and four cameras. Recently I am not able to access my system via Arlo app it says access token denied and will not accept my password or allow me to reset it. It sends a link to my email but it goes back to the original screen and I am not able to enter a new password. I have not been able to use the system for a couple weeks now and cant find a trouble shooting topic that works to fix this problem?
DTesta,
You may want to try uninstalling & reinstalling the app along with rebooting the base station. Try logging in from your laptop or pc browser.
Hi DTesta,
Which app are you using (IOS or Android) do you see the same behavior using a web client from the computer?
DTesta,
