I've seen the "what's the difference between smart hubs" but I can't find anywhere if the original Arlo Wire Free Camera VMC3030 are compatible with any of the newer smart hubs. Does any one know?
All newer hubs/bases support all cameras. Older bases don't support newer cameras.
Yes, but unfortunately this link no longer says that: https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
@JamesC: Wire Free is missing from the list for VMB4000 and above (perhaps when essential cameras were added). Pro 4 is missing from the VMB4000 - not sure if that is a mistake or not.
Thanks both of you for your replies, very much appreciated.
I'll request this to be updated.
