App says offline
  • 2 Replies
  • 4646 Views
Leslieyount
App says camera is offline.  Camera has new batteries. Reset base to no avail.  Camera will not sync to base....just continues to flash blue for minutes. Went to settings and deleted device and started over to no avail.  Please help.  Thanks!
Have you opened a case using the Contact Support link below here?
Leslieyount,
Consider rebooting your base station (use the power on-off switch on the back) and reboot your camera (open and close the battery compartment door. Allow the base station to come back online with a solid green power and internet LED. Press and release (quick press and release) the sync button on the base station (you should get a blinking green camera sync LED) and then press and release the sync button on your camera.
Are you still not able to sync the camera?
