App Issues & Questions
One more question:
6) Why doesn't the audio work? I have tried it on iPad, iPhone, Windows. No luck...
- Don't know.
- Don't know.
- No activity log.
- Have you checked the rules inside the mode you're using? They can be adjusted up to two minutes of recording per trigger event.
- Official battery life is 4-6 months with a usage of 4-minute video footage per day. Or were you asking for alternatives to the regular batteries? Rechargeables are an option. They don't last as long as the single-use batteries, but are cheaper in the long run. Some people have modded their cameras to power them with an AC adapter, either by connecting to the battery springs in the battery compartment or by making use of a hidden USB port, also inside the battery compartment. But it requires drilling holes into the case or lid and sealing the inlet to maintain weather resistance of the case, so it's not everybody's cup of tea.
- The Arlo wireless cameras have no sound. Only the Arlo Q does, but that one is for indoor use only.
john_d,
1. We are currently investigating an issue causing inconsistency with the battery indicator across different clients.
2. This sounds like it could be the confirmation e-mail you get when first registering your system. Once you have everything set up an e-mail is sent to confirm registration and finalize the process. Check your e-mail and make sure you have completed this. (check spam folders to make sure this e-mail wasn't missed due to being marked as spam)
john_d,
2. Try attaching a screenshot of the message you are seeing on on your ipad so we can investigate this a little further.
3. I don't have any information on this being a future enhancement. I encourage you to visit the Arlo Idea Exchange and post on this topic there.
5. The Arlo Q is a wired camera that can be used on the same account as your existing Wire-Free cameras.
6. On the Basic plan you can have up to 5 cameras, an combination of Wire-free or wired.
7. Yes, the Arlo Q can be added to your existing account providing you have not met the camera limit for your subscription.
