Any way to fix "the camera is offline" remotely?
Just got and installed a camera which was very easy. But now it has gone offline. Since I want to use this to monitor my house when away on trips is there any way to get it back online remotely? If not it may be going back to the store. Thanks!
Basic answer is no...
You can't directly access the cameras remotely... it must go thru the base.
The only option you really have is to try and reboot the base ( which can be done remotely ), but in my experience unless its a connect issue does not fix the cam.
