HI,
We use more than 10 arlo cameras, different models, we use on the construction sites.
We are planning to get more.
My question is, any plan for business? Or I will need to pay $25 for each camera?
is 30 days the maximum time limit your cloud can record? no longer?
Business plans are listed in your account settings, under Subscription.
Thanks for your reply. When I press subscription, I only get 2 options
1. Arlo Smart
2. CVR PLAN
Thats all i can see. No business plan.
Am I pressing at the wrong place? I Cant find any other subscription.
When you select Change Plan in Arlo Smart, you should get a link to business plans below the Premier and Elite selections.
Got it.
Thank you
Thank you
