Amber blinking light on power LED then goes blank
  • 1 Reply
  • 2370 Views
abeckworks
I just moved, hooked up my Arlo base station the way I had in the past, but now the power LED will blink orange several times then go completely blank.  Any ideas?  I've tried searching the community and didn't find this same issue.
Assuming you mean the power LED on the base, it can only mean that 1) the power connection in the wall is faulty, 2) the power supply is faulty or 3) the base is faulty. Try a different outlet. If the same thing happens, open a case with support here.
