Swap cameras around to see if an issue with the camera or location.
The fix - to delete the app and re-download the Arlo App
I hadn’t done this (with the concern of losing all previous data, as this was something I had looked at earlier), but fed up with not having a resolution decided to try it
Deleted app, reinstalled the Arlo app
Yay - Amber Warning on Live Feed now disappeared & previous footage is still there.
Hopefully it may work for any other people who have issues with the app
Thankfully, I don’t appear to have to do anything further
Any reason for update? Worth updating? Don't bother? lol
Power cycled the base station and deleted and reinstalled the app.
Bloody thing still offline.
Glad I bought the set just recently, because if it doesn’t work by the weekend it’ll go right back to amazon.
Resetting the base station could be something I’m willing to try. But no way I resync all the cameras. They are mounted around the house. If I have to take them down they won’t go up again......
If the 3 green LEDs are lit on the base, the system should be working. It may be a display issue - have you tried both the app and a browser (or a second brrowser)? For the app, try both WiFi and cell service (work networks can be a problem if on WiFi).
Thanks for your efforts.
The 3 leds on the base are lit green.
The lan cable in the base station definitely works. Tried that (by plugging it into my laptop).
I tried the app on my iPhone. Reinstalled the app, tried again. Tried it on my home WiFi as well as cellular from work. Tried the app on the iPad.
Tried the website in internet explorer.
I restarted the base. Via the button on the back and by removing the wall plug.
Result of all this: base station and all cameras still offline!
It'll be a PITA but the fastest thing to try is to start fresh. Note all your settings and modes/rules before you start. Remove all devices in Settings, My Devices. Use the Add Device button on the Devices tab to claim the base. Sync the cameras. All should be good. No explanation for why you would need to do that.
Maybe it helps someone:
i was ready to reset and reconnect everything. So I deleted the base in my app. Then I thought I’ll try to add it again without resetting it first. The app then showed the base as connected but I didn’t get any live picture. After a hard restart of the app it actually worked again. Without reconnecting any of the cameras. They were still there.
So I’ll give it another chance. Especially since I wasn’t able to find another product that ticked all my required boxes 😉
