All cameras go off line
  • 10 Replies
  • 3212 Views
Djjeffa
I have 3 cameras all with new batteries and the farthest one is 30 ft from the base station but for some reason all 3 will drop offline. Ill come home and check my internet and its up but the cameras will all be offline and if I reboot the base it will usually come back online. Any ideal on the cause or fix?
10 REPLIES 10
mgreivell
offline again. The fixes suggested can't be performed because I am not there.
ShayneS
Hi @Djjeffa
Is it possible the ethernet cable is going bad? have you tried to replace this and test again? Did you reboot your router by chance?
Djjeffa
Thanks for the reply but I changed the cable and rebooted the router many times.
ShayneS
@Djjeffa
When did this issue first occur? Did you happen to move anything close to the base station causing an interference?
Djjeffa
Nothing has been moved. It was down for over a day then recorded 2 events the next day then nothing till I reset it.
ShayneS
@Djjeffa
Have you tried to reboot the cameras by opening and closing the battery door & testing again?
Djjeffa
Done that as well but dont think that would have been the problem because all 3 camera go down.
ShayneS
@Djjeffa
What is the status of the LED lights when this issue occurs?
Djjeffa
I cant get it to act up while im home but if it dose ill let you know.
Djjeffa
So the cameras were down for 3 hrs. All 3 lights on the web one would flicker some times i couldn't get a live view until i logged out and back in.
