All Cameras Are Offline On Two Base Stations
Was there an update recently that would have caused base stations at two separate addresses on two separate routers to go out of service? I powered off one router and the app sees that router but none of the cameras will connect. I will not be able to look at the other base station until this weekend..
Last base station update is listed as the 7 th
I too am having the same problem since the recent upgrade. First it said they were offline. Tried to resync and would not connect then tried to remove the device re-add and resync and still nothing. Any help would be appreciated.
I am afraid as this appears to be connected to the removal of the basic plan which I am a bit frustrated about as this is why I chose this product . The plan was a part of the product that I purchased and now they are taking that away...
Did you ever find a solution to this? I am still having trouble connecting my Wire Free cameras to the Base Station. I was able to connect my ArloQs.
