Adding additional cameras to existing Arlo system
i bought your two camara deal later i bought two more camaras how do i get all four camars displayed
You register them just like you did with your first two cameras.
So:
- Press the synch button briefly (on the right edge of the base station). Make sure the third LED from the left is blinking on the base station.
- Briefly press the button on the new camera. Its light should start blinking in blue. When it blinks rapidly (again in blue) and then goes out, the camera is synchronized/registered with the base station. If the camera blinks orange, something is wrong. Open the battery compartment for a few seconds, then try again. (i.e. go back to step 1).
- Discover your new camera as a new device in the UI and configure it to your liking.
- Repeat with your fourth camera.
