Adding a second camera
  • 2 Replies
  • 3492 Views
Kingfred911
I add a second camero on my security system, but in my arlo app on my iphone I have a little red triangle when I check the second camera in the setting, why??? I can't find where is the problem. Excuse my english I'm french.
The red triangle means there's a firmware update is available.  It should automatically update overnight.  You can also opening and closing the battery door on the camera to try to force the update to occur.
Means there's  a software update  ( prob for the camera )..check settings
