Adding a Pro cam for casual two-way communication
  • 2 Replies
  • 3890 Views
JRTinz
Greetings:
I have a "plain" Arlo 3 cam system, and have been considering adding an Arlo Pro cam to my set up.  Basically I have my existing three cams set up for security, but would like to add a Pro cam. Essentially the idea is my wife to use this cam to see and talk to me(well, the grandson anyway) while she is at work.
If you have done something similar, are you satisfied with how it worked out for you?  I could use my cell phone, but in theory this seems more convenient.
Thanks in advance!
-jrt
There would be no issue adding a Pro camera...
that said, some of the users report it works great , and some not... mostly depends on the phone used.
The newer iOS has had issues now and then with audio.
As to me, I mostly use the computer...and with that audio has been ok with Pro and Pro2 cameras
JRTinz
Thanks TomMac...
I sort of thought that would be the case. Always hard to tell from reviews regardless... on anything. Most are prone to make the effort to complain than to praise, so your reply is likely the best I could hope for.
I like to carry around a cam and place it where my wife can look in on our grandson when I'm watching him, so a "spare " Arlo will likely work out pretty slick in any case.
Thanks again...
-jrt
