Adding 2nd Arlo system in another location using same phone
  • 3784 Views
Arlo4Lee
I had installed a 2 cameras system in my work with app on my IPhone.
Now I just purchesed a 4 cameras system and plan to install in my home.
Here are my questions:
1. Can I just go to add device to add the new base and 4 cameras? Will
    it be over the max. 5 cameras limitation for basic free service?
2. If it'll over, what options do I have beside to upgrade to higher lever?
3. Can I use my wife's email to create a new account then use my phone
    to share? However, My phone already share one camera with my brother.
    How to share additional 4 cameras?
Use #3. Sharing has no effect on the camera count. It's the total number of cameras per master account. Sharing the cameras makes it easy to see them all in one login.
Arlo4Lee
Thanks jguerdat,
So at Grant Access have her send invite to me or I send to her in order to share the 4 cameras?
Whichever you choose - it doesn't matter with the exception that a guest account with full privileges isn't quite the same as the master account when it comes to fully manipulating the system. Choose according to whether it matters more one way than the other.
