Added a second hub and 3 cameras.
  • 4 Replies
  • 1364 Views
Jrwelder23
I've added a second hub along with 1 flood light and 2 pros I think. They aren't recording into the 7 day cloud library. The original set up and cameras are still recording into the 7 day cloud library. What am I doing wrong?
Hub is VMB4540r2
Cameras V10 ?
Floodlight H4 ?
@Jrwelder23 wrote:
Cameras V10 ?
Floodlight H4 ?
I'm not home I grabbed that info from the Camera details from the app.
As I mentioned, you can also get the correct model information by going into the support section in the app.
What you are looking at is the hardware revision info, not the actual model.  These codes aren't unique, so they aren't very useful.
@Jrwelder23 wrote:
And oh ok. well wait. I have a floodlight hooked up to the original hub and it's still recording.. What's the difference here? Is it because the second floodlight is attached to a newer hub? Which requires a subscription?
The floodlight does require a subscription to get recordings.  Likely you are still getting the trial subscription for it.
Note also that the free cloud recording for the older cameras is limited to 5 unsubscribed cameras per account.  If you go over that limit you lose free cloud recording for all the cameras.
@Jrwelder23 wrote:
Cameras V10 ?
Floodlight H4 ?
This bit isn't useful, as these are not camera models.  If the cameras open, try removing them from the housing and removing the battery.  There is a label inside that has the correct model information.
You can also go into the support center of the app, select the camera, and scroll down to the product field.
 All currently sold Arlo cameras require a subscription (that started in 2018 with the Ultra).  That includes the Floodlight, Pro 3, Pro 4, Pro 5s, and all Essential models.
Jrwelder23
This bit
Cameras V10 ?
Floodlight H4 ?
Jrwelder23
I also thought that the floodlights didn't need to be attached to a hub, what if I just add it without adding it to a hub will this be a better solution so I can see recordings?
A little new to the system and just trying to understand all of the differences in systems.
@Jrwelder23 wrote:
Cameras V10 ?
Floodlight H4 ?
