  • 4 Replies
  • 3216 Views
Jlgilly
Add on camera won't sync. Have followed all manual steps. Hard restart, new batteries, and nothing seems to work. Camera flashes blue and then goes to an Amber flash.
Define hard reset - using the reset button? If so, you have to start fresh after removing all devices in Settings, My Devices. If you mean a power cycle, make sure you're only pressing the base sync button briefly - don't hold it.
Jlgilly
Have done both per instructions and manual. All of our other cameras were resynced and operational.
Jlgilly
Also The amber light flashes is very fast.
Jlgilly,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
