ARLO not recording when motion is detected-settings are correct
  • 1 Reply
  • 2131 Views
WWLightning
One of my three regular Arlo cameras do not record upon seeing motion.  I get notification of motion but no recording is registered.  I did try to record manually, and it worked and registered in the history.  I have tried changing the setting to no record and saved it and then changed it back to record and saved it.  No change.  What am I missing or need to do?
First two things to try;
1) reboot the came by opening and pulling battery then replace.
2) reboot base via the power button ( off - on )
