8 in 1 sensor & chime
Does anybody know how to make the chime announce the 8 in 1 sensor opening it is alerting?
Are you referring to having the sensor being used as a door open/close alarm? If so, go to the sensor's settings, click on Access and enable Chirp.
That Park works just fine with the chime. I want it to say "back door open" or "side door open" or whatever the door or window that's being opened is being called out on the chime as to the location of what's actually being opened.
You can't add a custom message for this. Whether it will ever be added is unknown.
