4th camera will not sync
New system, new batteries. 4th camera does not snch. Previous forum says solved, but from reading, it seems that 1 out of 4 of the cameras are often defective and you have to pay to send them back. Not too easy from Nunavut.
Is it solved or do I throw the defective camera nto Hudson bay?
aullannaaq,
What is the LED behavior when you attempt to sync the 4th camera (camera LED and base station LED)? Consider rebooting your base station using the on-off button and attempt the sync process again.
