- 2
I'm getting frustrated. I purchased a four camera kit. Three cameras have sync'd, but cannot get the 4th camera to sync. I have put about 6-8 hours working on this and I want to throw it out the window. I have removed the batteries about 20 times. Reinstalled them. Blue flashes on camera and then shuts off. Push sync button on base getting solid green light to flash (camera light, 3rd over). Push sync button on camera within 1 foot, other times two feet until blue light flashes never getting a fast blue on camera like I did on the other 3.
Tried resetting as suggested in community. Pushing reset button and sync.
Cannot get this 4th camera to sync. Please help.
At this point, you're left with resetting the base. Hold the reset button until the LEDs flash amber. Remove all devices from Settings, My Devices. Open and close battery doors. Make sure the power and Internet LEDs are green on the base. Start fresh using the Add Device button on the Devices tab to add the base and sync the cameras. Be sure to olny briefly press the sync button on the base.
If that doesn't work, you should either swap the system at the store or open a case with support using the Contact Support link at the bottom of the desktop version of these pages.
Well I have been trying to sync my 8th camera for a couple of months. Finally I got annoyed and contacted Netgear. I was told to send back the camera, which I did. Now I have received another camera, and it will NOT sync either. I love my arlo, I guess I am just getting a bad camera twice? I have sent another email to Netgear to get it resolved. HOPING the next camera will work!
Not sure why you waited months but make sure you're only pressing the base sync button briefly - don't hold it.
Jessicarandall7,
I apologize for the poor experience. Do you have a case for this issue open with the support team? If so, please provide me with the case number and I will review your case and escalate if needed.
- 2
