2 camera only one recording.
  • 3427 Views
Rva
Hi I have two arlo wireless cameras.  The one that is not recording shows the same exact time the other is recording motion.  I tried re syncing the one not recording but that did not work.  I would appreciate any help.
Joe
steve_t
Master Master
Have you checked that the RULES in your recording mode are set correctly?
Rva
Rules are identical for both
steve_t
Master Master
The one that isn't detecting motion - is the 'running man' symbol above the device preview image black or grey? Can you live view with it?
