2 base station hook up
  • 1 Reply
  • 1328 Views
fengshuikb
I have 4 Ultra2s hooked up to one base station, and want to hook up 3 Pro 4XLs to a 2nd base station.  Will the Pro 4XLs hook up automatically to the 2nd base station?  Also can the base stations  be in the same location, and can I install a longer ethernet cable from the router to the base stations?
Thks,
feng shui
DannyBearAgain
You can have multiple Base station at the same location, ensure that they are 6 to 10ft apart and same from the local router wifi to minimise interference.
you can get away with using a longer Ethernet cable, up to 300ft using CAT6 I recall.
when you add a camera ensure you select the correct base station to add it to.
