The new version solve some problems but give us at least one new: It crash everytime I try to press the mode tap. Are some of you other experience this?
I have deleted version 2.7.2 and reinstalled it, but the same thing happens. Has Android 8 in a Samsung Galaxy S7.
---Svein Olsen, Oslo, Norway---
(...and I hope Google translater do it well...!)
I hope this is gonna get fixed soon...
What are the fixes for this problem? Just started to happen today.
have you un-installed and re-installed the app?
Assuming this is for Android, reinstalling hasn't helped me. Sometimes the Mode tab works fine, other times, not so much.
Anyone else having this problem with the Arlo app - Android app ALWAYS crashes when the cameras are running in Schedule mode and I try to select Mode. Non-Schdeule modes usually work fine. I am running Android 8.0 and Arlo Version 2.7.1
I don’t use Android, but on iOS, the current version of the Arlo app is 2.7.4. A good place to start would be to update the app.
I'm having the same problems.
Selecting Mode crashes the app 90% of the time.
This problem only started in the past couple of weeks and I very much suspect the Feb update has broken something - at least for some Android users.
Yes - I've logged out & back in; restarted the phone; uninstalled/re-installed - problem remains.
It's still working on the iPad so at least Netgear haven't boken that app yet.
Same problem. Tried all the same fixes. Reboots. Reinstalls. Cache clears. Hardware restarts.
Was working ok until Feb update.
Sony XZ1C (G8441) Android 8.0.0 build 47.1.A.16.20
App 2.7.2_25500
An update of the app in Feb. 2019 crashes on 3 different Android phones. This is when going into 'Mode'. Resetting the router or reinstalling the app gets it to work for around a day sometimes, then fails again. Support informed me Arlo works only with Android 8.11 and up, the phones have 8.00, no updates available. All works fine on desktop, not usable on mobiles. Can I roll back to the old working version?
Not from Arlo, tho there are some android sites that carry prev version on the web
You take the chance ...
https://www.apkmirror.com/?post_type=app_release&searchtype=apk&s=arlo
@ShayneS wrote:
That is great to hear! let us know if you have any further questions.
To support Case # 40727401
I have sent a message to support if there is any newer fix on the way. For there are several of us now who are incredibly impatient.
After the last update every time i go to my MODE tab the android app crashes, no matter how long i wait. If i restart app and quickly click mode sometimes i have enough time to change one of my base stations back to active. Also i have a schedule setup and on the APP sometimes it showes the wrong mode or says disarmed with a clock by it even though on laptop it shows armed.
I too am having this same issue since the last update to Version 2.7.2_25500
I too have had the problem with mode crashing my the app. I was waiting for an app update but it is taking way too long for that. I contacted support and they reported to me that this is an issue that several customers are experiencing.
Is it too much to ask for Arlo to at least send out a notice to all their customers regarding this issue. It would save people a lot of troubleshooting hassle / wasted time to try and fix something that even arlo can't fix at this point. This is one of the main reasons why I am not paying for an Arlo subscription. I want a subscription but I said to myself that they have to be problem free for a minimum of 3 months before I do that. I guess that is an impossible task.
I have simple schedules set up with cameras/lights and I also have door bells.
My problem was experienced on the app version 2.7.2_25550 on my Galaxy S7, and Razer Phone 2 with both android 8, 8.1, and 9.
I guess it could be worse, I could have gone with Nest or Ring. So at least I don't have Amazon or Google snooping on me. lol.
So go into Devices, then Base Station and make sure the Time Zone is your actual timezone.
Netgear must have some QA issues if the wong timezone makes Schedule mode crash.
Hopefully this helps someone!
Nice guess, but, nope. I have the occasional problem but my time zone has always been set properly. In fact, I just checked my time zone (it's correct) and then went to Mode - the app crashed.
Yes - same.
Time zone checked ok. Still crashing.
