1280TVL multiple attempts to get the base station sync light to illuminate failed multiple times
** anothe model number for the Arlo 3 cam kit sold at home depot **
Make sure when you attempt to sync the cameras, you do ONLY A QUICK PRESS on the base sync button.
so, open and close the battery doors on the cameras to reset them,
Power button reboot the base
do above and a sec or two later push the camera button
a slow blue led to fast blue means it worked ( if blue to amber then NG )
