arlo essential doorbell without existing doorbell
Hi.
I purchased arlo essential doorbell and chime2. But I need to install them without an existing doorbell. how to install correctly. There is also a 24v transformer.
7 REPLIES 7
@Rasim wrote:
Hi.
Did you get the AVD1001 or the AVD2001?
Dear StephenB,
Its AVD1001.
Its AVD1001.
@Rasim wrote:
Its AVD1001.
You won't need the power kit, but you should save it in case you do add a traditional chime later on.
All you need to do electrically is connect the two low-voltage outputs from the transformer to the AVD1001.
I did that, but I can't connect. When scanning the QR code, there is no reaction.
Try the doorbell reset procedure:
https://kb.arlo.com/000062346/How-do-I-reset-my-Arlo-Essential-Video-Doorbell
I tried several times, but unfortunately it didn't work.
It may just be a faulty doorbell. Swapping at the store is the fastest method.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
