Wont connect to hub or router
  • 1405 Views
retiredcpo
Door bell wont connect to anything been trying for hours searching web ect.
The door bell was working fine  then just disconnected and now nothing.
everything seams to work fine get the white flashing lights
but wont connect
Tried a full reset and everything I can find on the net,,,
We have 2 cameras hooked up and they work no problem and they are further away from the hub..
The door bell is only 20 ft away from the hub with only the wall is mounted on inbetween
Submitted a ticket with support and have heard nothing back
any ideas how to move forward
thanks
If you can exchange it at the store, that might be the fastest step. Otherwise, stay on support using your ticket for possible faulty hardware.
retiredcpo
Bought it online with Amazon  so not even sure how I go about returning it
Ticket with customer service dont do no good if they dont respond to it
Very frustraited with this
when I first hooked it up only took a few mins to install and set up  Ive spent hrs trying to
get it to connect back up
Since it was from Amazon, just look at your order and see if it's within the return window. You can start the return/swap right there.
  • 1406 Views
