Wired video bell - gets stuck in a loop calling my phone
I've had so many problems with my Arlo video wired doorbell I can not state it enough I've already had it replaced already reinstalled it for some reason every time somebody rings the doorbell more than once it gets stuck in a loop where it just keeps calling my phone and I can't get the Chimes it ring more than once they keep telling me to Dismount the doorbell reset it mounted again I feel like I'm a monkey it's got to be a solution on this even uninstalled it or took it off the from the Arlo Hub and everything and put it back on and it keeps getting stuck in just by calling my phone even after the even was over 10 minutes later it rang the chime more than once after the fact tech support needs to seriously get up to par because this is ridiculous $200 for a doorbell that doesn't want to work most of the time it is ridiculous people
If you've replaced the doorbell and the same symptoms are still occurring this could indicate an issue with the transformer. Check your transformer to be sure it's supplying the correct voltage to the doorbell: How do I measure the voltage of my doorbell transformer?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
