Wired door bell cam 1st gen not powering up after removal for house painting.
  • 1153 Views
palcalone
@palcalone wrote:
What is the problem?
Can you check the voltage at the chime location?
It you have a traditional chime, you could also try touching the wires together and see if the chime rings.
palcalone
three is power there, if you touch the leads the bell rings.
Did you leave the doorbell in place for a while when you put it back?  There is a small internal battery that needs to charge.
After that it is possible that you will need to reset the doorbell
  • 1154 Views
