Just completed the initial install yesterday and was able to change the chime setting to NONE thinking that would activate the mechanical chime. I went the mechanical chime to reset the wiring. Now I am not able to make the change in the app or on the website.
It would appear that you need to remove and resync the doorbell to correct this.
Needed to edit: current setting is NOT CONNECTED instead of NONE.
That was my next step but wanted to try here in case there was another option.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
