WiFi signal strength
  • 3987 Views
bbtaylo212
Doesn’t seem to have as good of WiFi signal strength as my Arlo Pro base station?
bbtaylo212,
Arlo Video Doorbell connects directly to your home router rather than the base station (unlike your Arlo Pro cameras). This means signal strength is determined between your router and the doorbell, rather than your base station and the doorbell. How far away from the doorbell is your home router? Are you able to move it closer to the doorbell to improve signal strength?
Davmitrani
I’m having the same issue and unfortunately can not move router closer to front door.
Any other suggestions.
If it's really causing issues (as opposed to just showing a low signal strength) you could use a WiFi extender to connect the doorbell to instead of the router.
  • 3988 Views
