Video doorbell
Viewing live images on echo show 1 with my other Ultra cameras are fine.
I have tried to lower resolution on doorbell, reinstall, restart arlo hub disabled and re enable Alexa skills and no luck. Still not able to view live footage of doorbell camera on echo show 1.
Just installed a Video Doorbell today and I am seeing same behavior. Along with the doorbell I upgraded my hub to the VMB5000. I can view all my Arlo Pro cameras(3) on my Echo Show 1st generation and my Echo Show 5. I can not view video from the doorbell on either Show.
Alexa says OK and puts up a screen saying waiting for Arlo but it eventually times out.
{edit]Just saw other thread, and lowering Video Quality did work.
ArloUltra83,
Try lowering the resolution on your doorbell. For more information, take a look here: Why can’t I view videos from my Arlo Video Doorbell on my smart home device?
Done that lower resolution to 1080 then 720 no luck.
Call Arlo Support no help.
At the end Arlo Support says it’s a known issue with live stream of video doorbell to Echo.
@ArloUltra83 did you try live streaming from the camera with the app or web portal before trying it through the Echo show?
I had to do that once after changing resolution before it would stream though the echo.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
