Setup door bell now won’t power on
Initial setup.
Went through each step; got to the connecting part and received solid lights around button, pressed the button to connect and the lights would not blink. Pressed and held button for a few seconds and still nothing. Turned power off, check connections at chime and behind door bell, all connections were good. Breaker back on and no lights on button. Breaker off, disconnected Arlo doorbell, hooked up old doorbell, it works. Reconnected Arlo doorbell again and no lights. Need help.
Fastest resolution is to swap at the store for a faulty doorbell.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
