I have an Arlo 3-camera system which uses a VMB3500r4 and I believe Arlo Pro2 cameras. I would like to add a video doorbell, but it appears that they are not compatible with that base station.
1: Which base station(s) can I switch to that would support my earlier Pro2 cameras but allow me to add a Video Doorbell 2K | 2nd Gen | Wire-Free/Wired Option camera
2: Does the Video Doorbell 2K | 2nd Gen camera require a data plan to work, or does it allow for answering, short-term storage of videos, etc. like my cameras already support.
3: What are the differences between the base stations, say VMB5000 | VMB4540 | VMB4500 | VMB4000 ??
All the currently sold cameras require a subscription for cloud storage. Some do use direct access to local storage instead, but that can be complicated to set up, and it has a lot of restrictions. That feature does require a VMB4540 or VMB5000 smarthub.
If you are willing to pay for a single-camera subscription for the doorbell, then you can connect it directly to your home wifi (avoiding the need to purchase a new base).
Currently sold bases are the VMB4540 and the VMB5000, so the only reason to analyze the VMB4000 and VMB4500 are if you are getting a used base. Both smarthubs are compatible with your old cameras and all doorbells.
The VMB4540
- is less expensive
- is single band (2.4 ghz)
- uses USB storage (ideally a thumb drive) for local recordings
The VMB5000
- is more expensive
- is dual band (2.4 ghz/5 ghz)
- uses a microSD card for local recordings
The doorbells are all single-band (2.4. ghz) devices, so the 5 ghz band in the VMB5000 won't matter unless you add 5 ghz cameras to the base later on. Most outdoor cameras would end up using 2.4 ghz anyway, since it has more range than 5 ghz.
The VMB4540
- is less expensive
The VMB5000
- is more expensive
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
