Redlight
  • 8 Replies
  • 2235 Views
  • 5 In Conversation
Bigcity141
I just installed my Arlo video doorbell and it has a red light around the bottom where it should be white how do I get it to turn white
8 REPLIES 8
Are you referring to the "ring" around the push button or the red IR LED used for night vision?
https://kb.arlo.com/000062326/What-do-the-LED-behaviors-on-my-Arlo-Video-Doorbell-mean
04pie
Interested in the reply regarding a red light around the button as I'm experiencing the same issue atm.
It starts white twice and then goes red.
04pie,
Take a look at the article linked above. A solid amber LED indicates a power issue, you may need to check the voltage of your transformer to make sure it meets the minimum requirements.
04pie
Thanks JamesC.
I was getting 27v from my power source. Too much I presume.
After reading these messages it seems that I need to subscribe to a plan to have this working. Is that correct?
A subscription won't help a power issue. Install an appropriate transformer and try again.
308665
Arlo wired video doorbell solid red and bell won't ring A transformer issue?
308665
Yes
308665,
  • 8 Replies
  • 2236 Views
  • 5 In Conversation
