Paid cloud record time
Does the doorbell record ALL motion until motion stops, regardless of how long motion lasts (30 mins, 1 Hour etc)?
Also is there any cooling off period between each recording?
I currently have both these features with my current setup and wondered if arlo is the same.
Any help appreciated
First, the definition of "record until motion stops" means the camera, not your eye, has to be detecting the motion. Many folks have glossed over that. ANd, no, Arlo records up to 5 minutes in that case after which recording stops, there's a brief reset and then will start recording again if motion is detected.
ANd Arlo doesn't do what Wyze does - record and the "cool off" for 5 minutes. The brief reset time is ~5-10 seconds.
So if there is say an hour of motion, it records 5 minute clips with 10 second gaps in between each clip?
NOthing changes between having a subscription or using local recording. So, yes, 5 minutes MAX (as long as motion can be detected by the camera) with the brief reset between the recordings.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
