  • 18 Replies
  • 4851 Views
6400Feet
Just had my new video doorbell installed (wired) and it's awesome. Just one problem it's not detecting package deliveries. I have setup package detection within my settings and when I check back on the recordings it's definitely see's the delivery at my front door. Any ideas? Thanks in advance.
18 REPLIES 18
ShayneS
Hi @6400Feet
I have a few questions for you
  • Do you have a screenshot of the package within view I can review?
  • Have you tried removing the package detection to another camera then back to the doorbell?
  • Have you tried rebooting your video doorbell within the Doorbell Device card Settings > Scroll all the way down > Restart
  • You can also turn off the power to the breaker for 10-15 minutes to force the doorbell to reboot.
6400Feet
Here’s a screenshot of a delivery which there was no package notification. Per your response, thank you, I did reset the device and I removed package detection and then re-applied it to this device ( it’s my only camera in the system). Please advise. Thx.
Spoiler
Spoiler
ShayneS
There is a chance the doorbell just missed this package do to the angle of the the box on the doormat etc. We continue to improve the accuracy of our features and welcome any feedback.
Just a side note, since you did reboot it & adjust the feature off/on, if possible can you try to use a box of some sort to test the package detection again? Maybe try placing it vertically on the mat and on the concrete. This will help determine if it is in fact missing the package when horizontally placed on your mat or having a general issue with detection.
6400Feet
Here's two more from today..it's clearly not working...
6400Feet
Second of two
ShayneS
Okay, I am testing further. I will provide an update as soon as possible. Thanks for the update
ShayneS
I spoke with the Dev team & there is a fix coming for this issue soon. I will provide another update as soon as possible.
Thank you
6400Feet
Thank you, please let me know.
ShayneS
HI @6400Feet
Are you able to test to see if this issue resolved?
6400Feet
It is still not working
ShayneS
Ok, I it looks like the fix wasn't deployed yet, but my personal cam detected a package so I wanted to check with you. I will let you know as soon as that update is pushed.
Thank you
6400Feet
ShayneS
This issue should now be resolved with a recent update, can you test again and let me know if you run in to any issues.
Thank you
6400Feet
Ok, I will remove it from package detection, restart the device and the re-apply it to package detection. I'll let you know the results. Thanks
ShayneS
@6400Feet
How did it go?
6400Feet
Nope, package detection is still not working/recognizing deliveries clearly happening right in front of doorbell camera..could this be a hardware issue? Everything else associated with this doorbell appears to be functioning correctly.
ShayneS
How is your detection working lately?
6400Feet
It's not working...still. I really don't think I, or any other consumer, should have to do the multi-step troubleshooting your company offered previously. So..is this a coding issue or a hardware issue? If it's a hardware issue can't you just offer me a new unit? The package detection has never worked although I have patiently completed multi steps.
  • 18 Replies
  • 4852 Views
