No chime or sound
  • 4 Replies
  • 1838 Views
thomas_crawford
I have a wired Arlo doorbell, it used the old doorbell chime.  Has been working fine for a while, all the sudden it has no sound.  No chime, no noise when the button is pushed, no sound at all.  Silent mode is not on.  I still get all alerts and calls when doorbell is rang.  Any suggestions on why the sound would not be working?
One thing you can try is disconnecting the doorbell, and then touch the two wires together.  The doorbell should chime when you do that.  If it doesn't, then the doorbell is ruled out - but it could still be the transformer, power kit, or chime.
WJJ1
This solution is going to sound crazy, but it worked.  I had exactly the same problem.  Everything worked fine for a month and then nothing except for the call, but no voice either way.  Video worked.  When troubleshooting we noticed that when I was talking outside by the doorbell, my voice was not coming through my phone via the app.  Instead, it was coming out of our new soundbar which has bluetooth and was paired to my phone, even though the soundbar was off (or so we thought).  I deleted the soundbar from my bluetooth list on my iPhone and then everything worked.  How that interfered with my mechanical chime ringing I have no idea - but it did.  And why the sound went through the app to the soundbar, I'm not sure because the link did not show as active.  But in any event, see if you have any bluetooth devices paired on your phone that might be interfering.
TM-Mormor
My doorbell does not chime.  Do I need to purchase Chime unit for it to work?
Do you have a mechanical or digital chime connected to the circuit?  If so, what it the manufacturer/model?
A Chime 2 is a possibility.
  • 4 Replies
  • 1839 Views
