No QR code video doorbell
  • 7 Replies
  • 5938 Views
Andrewk1005
I go through the steps to set up the door bell and get the flashing white LEDs but no QR code shows up on my phone. I’ve tried all my different WiFi networks, restarting the app, cellular data on/off, reset the door bell numerous times, turned the smart hub off and on and it still won’t generate a QR code and won’t connect to smart hub. I have cameras much further than the doorbell that are connected with zero problems. I’m about to trash this thing. Help!
This issue has been resolved with the latest release of the Arlo iOS mobile app. Please download the latest version from the app store.
7 REPLIES 7
Have you swapped at the store on the theory it may just be a faulty device?
potstom
But then there are a lot of faulty ones around! I have a similar problem with VMB4540 base.
Andrewk1005
Unfortunately I bought it off Amazon and the return period has passed. I may just try anyways. Nothing I’m trying will generate a QR code
Use the Contact Support link at the bottom here. Arlo devices come with a 1 year warranty.
Andrewk1005
I’ll try that. Thanks!
potstom
With today’s update on the ios app, the problem is perfectly solved. I would have liked to see it this way from the beginning - but I’m happy with the solution!
  • 7 Replies
  • 5939 Views
