New App experience with Chime 2
  • 5 Replies
  • 1701 Views
1makla
I have purchased a Pro 5 2K camera that I want to connect to my existing system. To do this I need to upgrade to a new app, but when I start on the process it tells me that my Chime 2 doesn't work with this new app. Does anyone know when an updated firmware is released for Chime 2? I do need this Chime, so what to do, is there a workaround so I can use the old app?
1makla
Hi again,
I followed the instruction in this tread and it worked perfectly.
Was easy to connect the chime afterwards, seems it can't be migrated as the doorbell camera can.
I think this should be said during the installation, instead of saying there's no updated firmware, cause
this stopped me, instead of helping me.
Happy that I could get help here.
5 REPLIES 5
I happen to have a Chime 2 connected to my account which has been using the new interface for a long time. WHat doorbell is it paired with? I suppose you could remove the chime from your account, migrate to the new interface and then add the chime back in.
1makla
Just says Arlo Video Doorbell Wired on the box. I'll try it out, if it works it's good if I'll ask again.
ShayneS
Hi @1makla
Just checking in to see how this is going? I personally have a Chime 2 installed with the new app experience.
1makla
Hi again,
ShayneS
@1makla
Awesome, I'm glad  I could help. Please let me know the know if you have any other questions.
  • 5 Replies
  • 1702 Views
